Hubitat C-8 integration within Fibaro Home Center 3
I’m wondering how I can connect Hubitat to Fibaro. Is there any chance to do this?
I have an HC3 for my home automation, but I also have a spare Hubitat C-8 that I couldn’t manage to sell, so I decided to use it as a Zigbee bridge in one of the rooms (the Zigbee bulbs were too far from the HC3, so it couldn’t detect them). Now I’d like to integrate it and trigger Hubitat jobs via the Fibaro app (Yubii). Any chance this is possible? Do you know if there’s a common interface I could potentially use?
Edited by Marcin Z
  • Marcin Z changed the title to Hubitat C-8 integration within Fibaro Home Center 3
Maybe through a service like IFTTT or otherwise maybe Home Assistant.
Edit: sorry, read your message again and realised you are after HC3 -> C-8  not the way i described... so probably useless what I wrote below... but will leave it here anyway... might get handy to others...
Hi @Marcin Z,
I have just upgraded my HC3L to HC3.
A part of the fact that HC3L was already on the edge of limit handling my growing zwave and qucikapp "library" I was hoping to use  some simple zigbee devices like Emos Tap Switch (rebranded Tuya in fact) - paired but did not work.
However, coincidentally I also had C-8 laying around and never really make any use of it - ugly UI, pain to do charts etc... good hardware, but the software is a disaster...
But! C-8 has a driver for Tap switch, hooray!
So what I did:
in C-8 in RM i created triggers for single and double click of each button which sends http GET request to HC3.
in HC3 I have created quickapp type remote control, added 4 buttons, created 8 functions for single and double tap.
and for now just created some block scenes which those buttons controlling - but in theory you can do "anything" via http calls from C-8
see some screenshots bellow....
Not sure that answer your question... but just sharing my experience and use of those together
Edited by Jan90
