Hard to really specify what is going wrong but I experienced:
- A aeotec trisensensor lost association with homecenter, had to delete it manually and re associate it. Others still work though so not sure if its because of this update
- I used the profiles function to set morning, evenings etc and seems completely messed up by this update. Some of the set profile devices work, others don't. At the moment no idea why
Hello! In order to check the problem, please give us the details about devices connected to profiles, and with which ones there were problems in version 5.163.59 (Beta). Many thanks in advance!
Hello @ErikP! We tried to repeat the described error with Aotec sensor, but we didn't reproduce it. I repeat my request for details about devices connected to profiles, and with which ones there were problems in version 5.163.59 (Beta). Many thanks in advance!
Edited by Kasia
Maybe refer to @ErikP, he doesn't read the post apparently
    Yes, sorry, on holiday. Will respond in couple of days...
    Yes so regarding the aeotec trisensor, I have multiple and only one had the issue so maybe that was just a coincidence. Regarding the devices that do not work with with the profiles, there are multiple:
    - fibaro dimmer 2
    - Fibaro switch
    - Fibaro RGBW2
    I also have an danalock 3 which does still work with the profiles. Also the new stable update did not change anything in this behaviour unfortunately.
    Thanks<
    Erik
    Hello @ErikP, we tried to reproduce the issue, but we couldn’t replicate it. Could you please provide more details about the setup, such as the configuration of devices, Z-Wave version, etc.?"
    Sure, I also ready do not understand why this is not working. Can not imagine its related to device type or z-wave version because I can control all devices true other scene's and manually in hc3 or app.
    So the setup is extremely simple:
    - I have some profiles: day, evening, night
    - in the profiles I have set light in kitchen and living room to go off and doorlock to lock when night profile is activated
    - When I activate night profile, the door locks but all lights stay on (but set to off in the profile). Pressing them off in the app or select the whole room and switch of lights does work without a problem.
    This issue appeared after updating to the latest beta and still exists now with the latest firmware release.
    Devices for kitchen:
    - 2x Fibaro dimmer v3.5, z-wave 3
    - Fibaro Relay switch v3.4, z-wave 3
    - 2x Fibaro RGBW controller v5.1, Z-wave 3
    Of course I can easily get the desired behaviour setting up scenes but it sort of misses the point of the profiles settings
