Recently upgraded from HC2 to HC3 and have already spent a lot of time trying to convert a scene that was used as a master switch. I'm learning about changes in lua, but unfortunately I'm still a complete newbie )
There are several lights in the room, and the scene was implemented to turn on the lights if everything is completely off,
or turn off the whole room if at least one source is on.
Can anyone help?
Edited by SyntezPro
Solved
  • SyntezPro changed the title to Please help with master switch scene
I am not that good in HC2 but try to help to make the HC3 scene working.
1.) I don't exactly know what your device "24" is with which you control/try to control the scene?
2.) When does startSource["type"] = "other" trigger?
3.) Is it a physical device or how do you want to trigger the scene?
In HC3 you have to set the Conditions part and the Actions part in a Lua Scene.
For the conditions part you can get more information here:
Or just use a Block scene and convert it into Lua
I would do something like this.
The sourceTrigger.type == "user" triggers the scene when you manually start the scene.
  • 1 month later...
    @Stycx
    Thanks for this line:
    but it didn't work for me. So I asked ChatGPT to do something with it :) and converted it for me, which made the scene work! Thanks again.
    The new lines look like this:
    • SyntezPro changed the title to Please help with master switch scene [solved]
