Yubii Home Center and HC2 - first white screen for long time then crashing
Hi @m.roszak,
This app never worked flawless with my HC2, was crashing all the time.
Now after some updates I try again and now first I get white screen for long time and then when finally I get to my HC2 it is still crashing on my iPhone with iOS 17.7.
I wanted to try to replace the old Fibaro app since I'm afraid that it will stop working if I update my iPhone to iOS 18.
It will be a big disaster if I loose functionality of the old Fibaro app and new Yubii Home Center does not work properly with my HC2 :-(
Can you share some info on this one, please?
BTW - When I switched back to my HC3 it is now also white screen for already more than 2 minutes? First rule of building apps and interfaces is that users get bored and worried if nothing happens for more than half minute. You should at lest put information on the screen with rotating circle and text that app is connecting to the gateway?
Hmmm.. after more than two minutes when I restated app it show my HC3 setup.
