Dropdown list check which are selected?
How to check which list items are selected?
regards
4 answers to this question
Hi @marczu_83 ,
There is example for dropdown list:
    thanks but i cant see anything about how to check which items are selected.
    i want to multiselect values and then press button and check which are selected :)
    Hi @marczu_83 ,
    if it is multi select checked then value returned is table of values and can be printed if table is json.encode(d).
    In example code there is function that is called when dropdown menu is used:
    If multi select is checked then self.mode is containing table with selected items. To print it change code to:
    To print separately each selected item you need to iterate through table:
    I wrote an article about the dropdown and switch button:
    Maybe it helps...
