Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New device control views
    A new way of controlling all device types from the Dashboard and preview in device settings for a better user experience.
2. Advanced user
    Introduction of a new type of user in the system with configurable access to system settings.
    From now on, the administrator can decide which parts of the configuration interface will be accessible to users who are not system owners.
3. Gateway Connection with Z-Wave Engine 3.0
    Systems using the new Z-Wave engine can now use the Gateway Connection feature.
4. New icons sets for sensors, binary and multilevel actors
System provides new sets of icons for presenting the devices and their states in more clear way. New icons apply to the following devices:
  • Binary Sensors
  • Multilevel Sensors
  • Binary Switches
  • Multilevel Switches.
Make sure that you are using the newset version of the mobile application for the best experience.
What's new:
Access
New UI for configuring access settings for normal users.
Alarm
By default, triggering an alarm will now result in sending a Critical Push (iOS) and Push (Android) for the new Yubii Home app.
Climate
A new way of direct zone control from the climate dashboard.
Dashboard
Adjusted icon sizes for better visibility.
Devices
Support for the dark theme for the new binding wizards in the mobile application.
Updated and added new binding instructions to the binding wizards.
Support for FGDW-002 in version 3.3 added.
Updated some parameter templates for various supported devices.
Minor UI/UX improvements in the binding wizards.
Improvements in Linked Devices (blinds).
Calibration of devices now available in advanced device settings.
FGT-001 external sensor temperature offset setting removed.
Added support for Zipato RFID.**
Gateway Connection
From now on, the upper limit for allowed slave hubs is set to 15.
Nice*
Added support for 2nd favorite position for Nice screens and blinds.
Added a feature for synchronous movement of blinds and shutters using Bidirectional radio protocol when used in group actions.
Other
From now on, restoring a backup or switching the system won't disable Remote Access for support if it was enabled before the procedure.
Minor UX and UI improvements.
Plugins
WakeOnLan plugin UI fixes.
Improvements in Nice Cameras plugin for better streaming performance.
Quick Apps
Added the possibility to set custom views for child devices.
Added the possibility to copy view definitions to the clipboard (works with HTTPS connections only).
Added the possibility to add custom view elements to thermostat views.
Improved webview performance.
Remote users
    Added the possibility to download and upload backup for Support and Installer user.
Scenes
Support for the dark theme for Simple Scenarios.
The Sound Switch device type added to Simple Scenarios.
Added new sets of icons for scenarios. New icons relate to:
    • Garage Door - open and close
    • Gates - open and close
    • Shutter - open and close.
Z-Wave
User Code command class support added.**
Simple AV Control command class support added.**
Inclusion and configuration of supported devices performance improvements.**
Added support for numerous old-gen devices (ZW300, ZW500 series).**
Disabled blur on the Z-Wave console during the device-adding procedure.
The Security S0 adding mode disabled by default.**
Zigbee
Improved performance for executing bulk actions.
Improved device availability-check module (marking devices as not reachable).
Support for MOES Human Presence Sensor ZSS-QY-HP added.
Bug Fixes:
Access
Fixed access rights for Advanced user.
Fixes in the UI for configuring rights for advanced user.
Backup
Fixed rare error during backup restoration.
Cameras
Fixed camera previews in some cases.
Climate
Fixed displaying values in Fahrenheit in the preview of the climate zone.
Dashboard
Fixed Drag&Drop for devices on dashboard, enabling the reordering of devices in room.
Devices
Fixed default icons for some device types.
Toggle action support fixed for the multiposition switch device type.
Fixed incorrect message when performing calibration of FGD-221 device.**
Fixed setpoint graph for FGT-001, which was not correctly shown in some cases.
Unable to add device in Security S2 if the PIN was incorrect (out of allowed range).**
Minor UI fixes in FGR-224/Roll-Control 2 advanced settings.
Refreshing advanced parameter values in the wizard binding procedure did not work correctly.
Fixed setting favorite positions for some blinds.
The icon for the Door lock changes according to the state of door lock.
Fixed setting user codes on Yale, Kaadas and other doorlocks.**
Fixed preview and tile view in dashboard for thermostats.
Fixed status presentation on Door Locks icons in some cases.
Fixed current override status presentation for thermostats control dialog.
Fixed issue with automatic change of device icon based on selected role for some device types.
Gateway Connection
Fixed issue with special characters in passwords for the slave hubs.
Update visibility for slave hub did not work correctly.
Fixed issue with connecting a new Slave hub that occurred in 5.162 Beta.
Fixed issue with accessing backups on the Slave hub in rare cases.
History
Some duplicated events removed.
Lack of icon for some events from FGT-001.
Nice*
Fixed support for MHouse protocol gates with new hardware revision.
BiDi-Multisensor is temporarily marked as disconnected when resetting some device parameters to default.
Notifications
Redundant intervals removed from the configuration page for event-type notifications.
Other
Minor translation fixes.
Minor UI/UX fixes.
User is logged out from the system after creating a backup.
Issues with saving Sprinkler Schedule.
Plugins
Fixed preview for the Sonos plugin.
Quick Apps
Added QuickApp is placed in the incorrect room in some cases.
Fixed issue with icons handling for some devices types like Weather provider.
Remote users
Fixed access for LUA Scenes for Support and Installer user.
Recovery
Fixed issue with updating the hub from Recovery from 5.140 to 5.153 Beta.
Fixed issue with checking system version when using the Repair option.
Rooms
Fixed issue with setting the default room icon after removing a custom icon from the system.
Cannot remove custom SVG icon in room settings.
Custom room icon is not visible when editing the room settings.
Fixed uploading custom icon for the room by Advanced user.
Scenes
When a new scene is added, the window does not scroll to the newly added element.
Possibility to type too long a name for Simple Scenario, which blocks the possibility to save it.
Lack of some scene icons after system restart in rare cases.
Small UI fixes in Simple Scenarios.
Main Z-Wave devices available in block scenes device selector.
Fixed issue with Scene Activation feature in block scenes.
Swapped triggering the scene on Doorlock state.
Update
Download progress bar visibility depends on the checkbox selection (beta).
Z-Wave
Error 500 in some rare cases during the Z-Wave device reconfiguration process.
Requesting Neighbors update action not always triggers correctly.
Fixed setting the device polling interval manually.
BiDi-Zwave device is added with a wrong system role by default.
Qubino 0-10V Dimmer parameters are being restored to default during inclusion.
Resolved issue with displaying Advanced tab for Door lock device.**
Fixed rare issue with starting the Z-Wave service when controller Node ID is different than 1.
Solved issue with mesh network reconfiguration not working.
Fixed issue with not hiding automatically console log after finishing adding or removing process.
Zigbee
Device removal procedure fixed.
State of the light in the system is synced with the real light state for Ikea lights.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Thanks 2
