Custom icons are not yet supported in the QA interface 😒
Any hope of a future plan?
Hi @m.roszak,
Until now I found that device of type com.fibaro.coDetector is not finished? It does not support custom icons and there is no property "state" as there is for CO detector on HC2.
There is property "value" but it is boolean true or false and yet there are 3 icons used to represent state Healthy, Moderate and Alarm which I assume show depending on state value 0-100ppm!?
BTW - weather provider and player now can use custom icons as before. THANKS!
@MihaiC ,
Can you give more specific information which QA interface (device) does not support custom icons?
"state" is only used for com.fibaro.fgcd001 (specific type for our own CO Sensor).
com.fibaro.coDetector is classic binarySensor, 2 states only (boolean).
The logic behind Healthy, Moderate and Alarm is not linked directly with the concentration, it depends on it but also depends on the time of exposition - its more tricky than it looks (
In general there are some exceptions which devices types does not support custom icons right now (like com.fibaro.fgcd001).
Type you mentioned (coDetector) supports the custom icons:
I assume you are using self:uploadExternalIconSet() to set those, current support for device's types below:
     -- single icon sensors/meters
     ["com.fibaro.energyMeter"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.humiditySensor"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.powerSensor"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.temperatureSensor"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.windSensor"] = QuickAppBase.iconProviders.single,
     -- binary actors
     ["com.fibaro.binarySwitch"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.doorLock"] = QuickAppBase.iconProviders.binary,
     -- binary sensors
     ["com.fibaro.binarySensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.doorSensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.floodSensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.smokeSensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.windowSensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.motionSensor"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.rainDetector"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.heatDetector"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.gasDetector"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.coDetector"] = QuickAppBase.iconProviders.binary,
     ["com.fibaro.fireDetector"] = QuickAppBase.iconProviders.binary,
     -- multilevel actors
     ["com.fibaro.multilevelSwitch"] = QuickAppBase.iconProviders.multilevel,
     ["com.fibaro.rollerShutter"] = QuickAppBase.iconProviders.multilevel,
     -- base shutter
     ["com.fibaro.baseShutter"] = QuickAppBase.iconProviders.baseShutter,
     -- other
     ["com.fibaro.deviceController"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.genericDevice"] = QuickAppBase.iconProviders.single,
     ["com.fibaro.player"] = QuickAppBase.iconProviders.single,
Hi @m.roszak,
thank you for details. Still I have uploaded my icons to the   ["com.fibaro.coDetector"] = QuickAppBase.iconProviders.binary, and then I get this:
As you can see instead of CO detector icon with green flower there is icon whit question mark.
Regarding the "state", for now I get "value" from my CO detector included in HC2. I remember that scene never triggered on "value", but only on "state". Do you know if Fibaro CO detector also changes "value" if CO level is higher than 0ppm for the duration that should activate alarm?
Just to clarify, I'm making slave devices for HC3 that are reading real devices included in HC2.
Fibaro CO changes also the value, but on "alarm" state, on "warning" it stays false.
We will check the icons.
    9 hours ago, Sankotronic said:
    @MihaiC ,
    @Sankotronic,
    It was a custom QA for a Door Lock. I mean „it was“ because in the end I decided to restore HC3 from backup and then update one more time to the last version. After reboot everything was ok.
    Hi, I'm missing one basic type. When can I expect it to be implemented? Thank you
    com.fibaro.multilevelSensor
