Qubino Flush dimmer 0-10V new template without external temperature sensor
Update 5.170 contains new template for Qubino 0-10V flush dimmer. I have added the dimmer to the old FW 5.140. On some later version there was a bug and it is no longer possible to use the external digital temperature sensor, child device is not added.
In this FW there is a new template, but after reconfiguring the device the child for external digital temperature is missing again.
So there is a bug in the template and it cannot be used with the digital external sensor. Please fix it.
ZW 2.0
Already reported ->
It is planned to be fixed in one of next versions.
If you got still the device with temp sensor (without template applied) please download its template and attach it here, it will help a bit.
    Hi, Michal @m.roszak
    I've uploaded all the devices, hope that helps. ZW2 engine.
    Thank you
    Thank you!
    One would be also enough because its the same template (it has the xml definition of the whole module) :)
