Hello everyone!
This morning I tried to turn on the light and nothing happened. This often happens, it's enough to reboot it.
But the reboot didn't help. Then I tried to log into the web interface of my Fibaro Home Center 3, but it didn't work.
As a result, I searched the forums and found how to enter recovery mode. I tried all the methods and even a factory reset - nothing helps.
I also noticed that I don't have any data in recovery mode at all, while others do.
Edited by Dariraze
Edit text
I think you should ask Fibaro for support. It started with the reboot thing. It isn’t normal you had to reboot often to keep the HC3 working. You couldn’t log on your web interface. Maybe it was just a network issue. Now you are already in recovery mode or factory reset. Hopefully Fibaro can get your HC3 running again before going any further away from a solution. Do you have backups?
    No, i not have backups (
