Door locks Pin Codes not remembered for viewing and can't update labeling without changing.
While I am extremely grateful that Fibaro has finally added pin code support to more door locks like my older Schlage locks I am running into two annoyances.
1) Unique PIN Error - When I go to label an existing Pin slot it won't let me without setting the pin, which is fine. However, if I attempt to use the existing pin it errors stating the PIN needs to be unique. This results in the extra step of setting it to a different PIN, saving, and then going back and setting it back to the preferred PIN per person. Not the end of the world as I don't expect to be adding a lot of already programmed locks, but it is annoying.
2) PIN not displaying - When clicking the eye icon to view existing PINs it simply changes from 4 small asterisks to 4 larger and higher placed asterisks. Not very helpful.  While I understand that anything not program through the hub wouldn't be known and this would be the expected function. I however would expect the hub to remember the pin for display after I set a new one. Otherwise, what is the point of the eye icon to display them?
