Hotfix 5.170.16 can not be installed -- Install button greyed out
Dear Fibaro,
The latest Hotfix does not let install itself, as the "Install" button does not become active.
How to do this?
regards, Jeroen
Have you clicked the checkbox „Accept terms & conditions“ (or similar)?
Edited by awlieser
You got Gateway Connection setup, all hubs must download the update first to start the procedure.
I have a bit differen't problem with my HC3. It says:
Aktualizacja nie jest dostępna przez Dostęp Zdalny. Użyj połączenia lokalnego.
How this can be fixed?
Access your HC3 using its IP address on the local network with your laptop, and then you’ll be able to perform the HC3 update.
