Can alarm scene be triggered by multiple sensors? HC3
Can the alarm scene be activated only when multiple sensors are triggered, not just one?
Right now, I have one sensor, and flying bugs keep causing false alarms (aeotec multisensor). I want to spread out the sensors and reduce the risk of false alarms for example when two sensors detect movement then start alarm.
Thank you
Edited by Johno2
5 answers to this question
Yes it's possible.
I use Eventrunner 5
rule([[pir_1:breached & pir_2:breached =>
1:armed=true;
log('partition 1 arm')
in arm you need to add pir_1 & pir_2
Succes
    Its not lua is it ? i forget to mention that i use hc3
    Edited by Johno2
    This is for HC3 reed the topic Eventrunner 5, easy system to automate your house. For example I have 5 QA's to automate my apartment, light, home cinema, power on/off and arming the apartment.
    Thank you. Does it override the default alarm panel behavior, or is it like scene Lua coding but in an easier way (Eventrunner 5)?
    Edited by Johno2
    In ER5 you create your own triggers and arming exact as you wish.
    It's easy to differentiate according to .....
