I recently updated my Fibaro 3 system from version 5.161.15 to 170.16, and a day later to 5.171.13 (beta). Unfortunately, I am not sure which version introduced the following issue:
In one of my scenes, I use a table of devices to switch off the lights by calling fibaro.call(devices, 'turnOff'). This worked fine before the updates. However, after the updates, running the scene now results in the error: "String expected, got table." or something like that.
This is puzzling, as the call uses a number, string or table.
To work around this issue, I now loop through the table and send multiple fibaro.call commands, but this is not ideal.
The workaround is simple, but not ideal...
This is a breaking change. I'm curious what FIBARO says about this @K.Drozynski :)
 I am running on 5.170.16 and tried it in quickapp and there this works
Edited by Neo Andersson
Did you try both Scene and QA?
Did not try scene..Evening i can try
So for me it works both in scenes and QAs, on FW 5.171.13
So, it seems that the bug is caused by the extra argument to turnOff -
Without that it works with a table...
(usually turnOff doesn't take an argument)
yeah there is something strange in 5.171.13, in my case scenes simply does nothing after 20-30min HC runtime, no trigger, no action, no errors, while QAs stopped to report tasks status or UI updates (definitely not memory issue). I had to downgrade my prod HC3.
probably this is also a reason why that FW had been withdrawn. It is no more available..
/monthly_2024_12/image.png.ce5b3fadf10a96ffbee398429ccd54c1.png" />
    Hotfix 5.171.15 fixed this.
    I had this problem in both QuickApps and Scenes.
    @jGab, you are right. The extra info 'sender' is for internal QuickApps (so that I know where the call is coming from) and not for devices.
    Even though it now works as it did before these updates, I will remove this extra info when the call is to devices.
    Thanks...
    Edited by NLWaard
