more and more devices use webhooks to return information about their status. It would be nice if fibaro could receive such webhooks.
It already exists, you can get data via HTTP(S) and send data to the HC3 via it's API.
I wrote several blogs about it:
  1. Please login or register to see this link.
  2. Please login or register to see this link.
  3. Please login or register to see this link.
So if you have a device and want to send data to it's webhook, or receive data from it, read blog example 1 and 2, if you want to send data to the HC3 read blg example 3.
    thanks for the answer. I didn't specify that I meant a webhook without authentication, just like you can do in n8n or node-red. Switch bot or Gardena can send data via webhook but doesn't support authorization.
