Momentary switches stop working after we leave job
We set up a Fibaro system for a customer and he is having issues with the momentary switches we set up on some dimmer 2 devices stopping working after we leave.
Still works on the Yubii app just not at the physical switch.
If we turn power off to devices it works as normal again for a while
Thanks Nathan
Hello, have you set Parameter 20 to 0 (Momentary Switch) already?. Do you have 2 or 3 Wire Setup? Can you Dimm the Light's via the App?
