LUA scene comparing the value of two devices.
Hello everyone,
I'm approaching LUA scenes that I've never done before (so advanced for me).
Premise:
Photovoltaic system with storage
Action:
Turn on the electric boiler (via fibaro switch),
when:
a) The battery is full (99/100%);
and
b) The panels' production is active (electricity production).
c) Internal home consumption is less than panel production in point b.
I created a block scene with the devices and then transformed it into lua and this is the conversion.
id 567 =battery;
id 561 = Panels;
id 563 = internal consumption
id 534 = Switch (Boiler)
DECLARATIONS (Conditions/Triggers)
ACTIONS
How can I create a Lua scenario from scratch and check the value of the two devices b and c?
thanks in advance.
Fab...
Hello
i have similar kind
can anyone help out like Room Temp =( Set temp-1) DEGREE THEN FAN MODE
Room Temp >=( Set temp-2)  OFF MODE
Room Temp <=( Set temp) THEN COOL MODE
i need LUA code for above condition execution
Edited by Nadeem
As a newbie it has been very good (for me at least) to use for instance Chatgpt for LUA-code generation.
I asked the AI from this thread and this is what i got as response. Please do not hold it against me as I did not test the code and I only posted to suggest getting help from todays very accessible AI services...
First triggers:
then the actions
Finally some explanation:
Detailed Explanation
Key Functions
  1. getDeviceValue(deviceID)
    • Retrieves the current value of a device using Fibaro's API.
    • Checks if the device has the required value property and converts it to a number.
  2. isBatteryFull()
    • Checks if the battery value is greater than or equal to 99.
  3. isPanelProductionActive()
    • Ensures that the panels are actively producing energy (value > 0).
  4. isConsumptionLow()
    • Compares internal consumption (563) with panels' production (561).
    • Returns true if consumption is less than or equal to production.
  5. controlBoiler()
    • Evaluates the three conditions:
      • If all conditions are true: Turns on the boiler.
      • If any condition is false: Logs a message and ensures the boiler is off.
Final Steps
  1. Save the Script:
    • Paste the triggers and action script into a Lua Scene in Fibaro HC3.
  2. Test the Logic:
    • Simulate changes in the devices' values to verify behavior.
  3. Debugging:
    • Debug messages are included to track execution in the Fibaro HC3 console.
Edited by Whswede
