This is a device downloaded like other devices directly in the gateway. Any solution? Thank you
New Beta
Old firmware Fibaro
I have the same problem, I just bought a HC3 and I can not add the Philips HUE, or I can add it but I can't configure/add the IP adress of the hub
Hi @petro_cz ,@alexebog ,
Do not use HUE plugin. There are better solutions in QA format that can be found here on forum download section.
I'm also working on my solution for Philips HUE integration and I hope will be available in the 1st quarter of the 2025.
    Hey, can you recommend a favorite? (QA) I like the simplicity of the default app, it just works and it works immediately, I use it for lights.
    Thank you
    Hi @petro_cz ,
    Well, my favourite HUE QA will be my own when finished. It will be HC3 ALC (Advanced Lighting Control) compatible same as it is on HC2 with support for HUE scenes and effects.
    Another one that I try is:
    made by @jgab
    Also there is another one made by @petrkl12:
    but I never test it.
    • 3 weeks later...
    I experience the same issue 😕 It would be nice to understand if this will be fixed or if the plugin will be discontinued...
