Hello community!
ZigBee no longer works since this update!! 😔
other people having the same problem?
2 hours ago, jjacques68 said:
Hello community!
It works, but somehow strangely, I keep disconnecting powered devices.
    in my case, no more data coming back form sensors...
    they are all "disconnected".
    Edited by jjacques68
    It looks like the devices were simply deleted from the database
    This is what happened to me when fibaro gate changed the zigbee channel after rebooting!
    For some devices, just press the reset button and it will connect
    I try the reset button, but no response...
    So, I must to include the devices again... :(
    The backup restore may help, just simple restore - not with old version.
    There is still an issue in SDK which we are trying to resolve with the chip producer for some time now - in rare situations this happens.
    • 2 months later...
    On 9.12.2024 at 13:08, m.roszak said:
    Przywracanie kopii zapasowej może pomóc, po prostu proste przywracanie - nie ze starą wersją.
    Nadal istnieje problem w SDK, który próbujemy rozwiązać z producentem chipów od jakiegoś czasu - w rzadkich sytuacjach tak się dzieje.
    I have the same problem - if I could block or manually select the zigbee channel it would make the whole game easier
    in what rare? everyone has been writing about it here for a year @m.roszak - stop joking already
    • 3 weeks later...
    Its rare, believe me. I am not sure if you know what everyone means ;)
    As for the issue workaround in SDK, we got this implemented in upcoming beta.
    25 minutes ago, m.roszak said:
    To rzadkie, uwierz mi. Nie jestem pewien, czy wiesz, co wszyscy mają na myśli. Jeśli ;)
    chodzi o obejście problemu w SDK, zaimplementowaliśmy to w nadchodzącej wersji beta.
    I spent hours, and the system works for me. I initiated an interesting problem. One temperature and humidity sensor on zigbee broke down and caused the system to freeze. I threw it out of the system, disconnected it. and Everything works without any problems.
