After my update (5.171) I get error messages in my scenes. After I assign, calculate and use variables in the hub.setTimeout() function, I get the following error:
[08.12.2024] [11:35:36] [ERROR] [SCENE860]: stack index 1, expected number, received number: not a numeric type that fits exactly an integer (number maybe has significant decimals) (bad argument into 'int(unsigned int, const sol::basic_protected_function, false, sol::basic_reference >&)')
Is this a bug in the update?
If you manage to give the time as a (large) float you get that error
Try to check/log the type of the value before you call, ex.
It should be an 'integer'
    Thank you @jgab. I have now found a temporary solution by adding the math.floor() function. example:
    local s = os.date("%S")
                local timeout = math.floor(60000 - (s * 1000))
                fibaro.setTimeout(timeout, function() -- wait 1 minute
                    awayTimer()
                end)
