Sunset and sunrise trigger scenes are not working
I migrated from Fibaro Home center 2 to 3 but Sunset and sunrise scenes are not working. I have pasted the screenshot I think Fibaro 2 block scenes were much better then Fibaro 3.  What I am missing over here,  I believe based on the location it should get the Sun set and rise details as we could do this in Fibaro 2. Please advise as I want to turn on the light few hours before the sunset.
The scene is correct and should work properly - must be a problem with location settings - pls check those
    I have checked the location and it's correct just want to turn on the  lights couple of hours before the sunset
    It should work like this. If you activate the scene manually (you then bypass the conditions), does the light goes on?
