stack index 1, expected number, received number: not a numeric type that fits exactly an integer error
Hi, since the last update I cannot have a timeout formula like
fibaro.setTimeout(1000*60*60*5.5, function()
If i have this 5.5 that multiplies any other big number, the result is this error message:
[ERROR] [SCENE4]: stack index 1, expected number, received number: not a numeric type that fits exactly an integer (number maybe has significant decimals) (bad argument into 'int(unsigned int, const sol::basic_protected_function, false, sol::basic_reference >&)')
Changing it to 6 worked fine. I believe this is a bug that should be fixed.
Regards
No, it's not a bug. Allowing a decimal number is a bug.  Truncate it to a whole number if you need to
or redefine the function to allow a decimal but truncate it
...if you have that problem in many places in your code.
  • 3 weeks later...
Hey Guys, I'm having the same issue recently regarding a wake up automation on my lights. In the morning, I've my bedroom lights to gradually go up at a specific time, for about 15 min.
The last few days (after the update) it stopped working and I'm getting a similar error - stack index 1, expected number, received number: not a numeric type that fits exactly an integer (number maybe has significant decimals) (bad argument into 'void(unsigned int)')
I don't have decimals set by myself on the code and the increments on light and timer values are all integer also. Any idea of what could be causing this?
The code I'm using:
%% properties
%% globals
_ledstripe = 171; --light id
_spotlight = 41; --light id
_maxValue = 100; --Max value you want the light to be
_duration = 15; --The time in minutes to go to the max level
fibaro.call(_ledstripe, "setValue",0);
fibaro.call(_spotlight, "setValue",0);
fibaro.sleep(200);
fibaro.debug('Start Wake-up Light');
duration = 60 *tonumber(_duration);
duration = duration /_maxValue;
for variable = 0, _maxValue - 1, 1 do
 local newValue = tonumber(fibaro.getValue(_ledstripe, "value")) + 1;
 fibaro.debug('Increase value to ' ..  newValue);
 --Increases the value of the lamp
 fibaro.call(_ledstripe, "setValue", newValue);
 fibaro.call(_spotlight, "setValue", newValue);
 --Waits before the next step
   fibaro.sleep(duration *1000);
fibaro.sleep(30 *60 *1000);
fibaro.call(_ledstripe, "turnOff"); --turn OFF
fibaro.call(_spotlight, "turnOff"); --turn OFF
duration = duration /_maxValue; -- result in float/decimal number
   fibaro.sleep(duration *1000); -- call sleep with decimal number
Thanks jgab, not sure why/how that would result in a float/decimal number.
_duration = 15
_maxValue = 100
during the sequence I do:
duration = _duration*60 - This would be 15*60=900
duration = duration /_maxValue - This would then be 900/100 = 9 which is not a float/decimal number.
Not sure I'm following your logic / results there :S
(Still not getting why...but applied the math.floor () suggested and is back working 🤷‍♂️ - Thanks for your help jgab)
Edited by Bruno Nunes
3.4.1 –
Lua supports the following arithmetic operators:
  • +: addition
  • -: subtraction
  • *: multiplication
  • /: float division
  • //: floor division
  • %: modulo
  • ^: exponentiation
  • -: unary minus
With the exception of exponentiation and float division, the arithmetic operators work as follows: If both operands are integers, the operation is performed over integers and the result is an integer. Otherwise, if both operands are numbers or strings that can be converted to numbers (see
), then they are converted to floats, the operation is performed following the usual rules for floating-point arithmetic (usually the IEEE 754 standard), and the result is a float.
Exponentiation and float division (/) always convert their operands to floats and the result is always a float. Exponentiation uses the ISO C function pow, so that it works for non-integer exponents too.
Floor division (//) is a division that rounds the quotient towards minus infinity, that is, the floor of the division of its operands.
Modulo is defined as the remainder of a division that rounds the quotient towards minus infinity (floor division).
In case of overflows in integer arithmetic, all operations wrap around, according to the usual rules of two-complement arithmetic. (In other words, they return the unique representable integer that is equal modulo 264 to the mathematical result.)
This was a bit different in the case of Lua 5.2 that only had the 'number' type. So, I expect that external C libraries just casted it to an int and it worked. These days 5.3> Lua's numbers are either float or integers(hidden behind a common 'number' type, but we can use math.type(..) to check), but when external C libraries gets a number they need to make an decision if it's a float or an integer...
