Brors94 115
If you got a room without motionsensor, but want an easy way to change scenes this Scene controller might be the thing for you
Download:
Check out:
Scene controller for rooms without automated/motion lights.
upload it into a room with lights and it finds the lights in the room automatic.
(or use Qvar roomID of the room you want to control)
2standard scenes turn on and turn off
and 6 custom scenes you can rename in the qvars.(scene1, scene2,...)
To save scnes set the light you want, then hold the save button for the scene you want to set for 2sec. and see the label update the values.
To use it with button/remotes, just make a scene that call the set buttons.
Now you got an easy way to change scenes without haveing to do changes in scenes to each light later. Just set it the way you like and save. Boom new settings done
label can be changed colors with the Qvars color1, color2...
It also support Language:
en - English
no - Norwegian
de - German (thanks stycx -
pl - Polish (thanks raffsa -
fr - French (thanks Tony270570 -
if you could help me make support for other languages just hit me up on the forum:
Or in this thread:
Also post in the thread above if you got some suggestions or wishes
Special Thanks to @jgab
Nothing could have been done without his Eventlib and guides on the forum!!
changelog:
20.12.24:
First Release
15.1.25
Bu fix with Colorprograms and energy device showing in the select list on rgbw firmware 5.1
Edited by Brors940 answers to this question
