Lua Christmas Lightszene or Light on so long movement, Change from HC2 to HC3
Hello everyone,
I'm just changing over and trying to implement the scenes mentioned in HC3.
What I quickly noticed is that you can't simply copy the Lua code from HC2, as HC3 apparently interprets the code differently.
I then created block scenes with the Sunrise function and wanted to merge this code into a Lua code.
Is it possible in this way, probably not really.
/monthly_2024_12/image.jpeg.0e7ad5228a33a66f2cca25b2fe959eed.jpeg" />
Edited by Microby
Please read the forum rules, before posting in Spanish.
    my language is not Spanish, but German. Sorry. I have changed it and hope that this is now OK.
    Where is my error in thinking here? The scenes run individually.
    I have built a block scene for each individual condition, i.e. "on in the morning" and "off after sunrise" and "on before sunset" and "off at night", which also work. I just wanted to summarize everything in one scene and only combined the Lua code from the individual scenes.
    Edited by Microby
    • Microby changed the title to Lua Christmas Lightszene or Light on so long movement, Change from HC2 to HC3
    The Szene "Light on so long movement" is a Timer-Szene.
    This is the code from the HC2:
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    %% properties
    239 value
    253 value
    %% globals
    -- VARIABLEN (Bewegungsmelder muss oben unter %% properties aufgeführt sein)
    local scene = 53 -- ID dieser Szene
    local motion = 239 -- ID des Bewegungssensors
    local switch = 485 -- ID des Relay Switches
    -- Lösche doppelte Szene(n)
    if (fibaro:countScenes()>1) then
     fibaro:abort();
    -- SCHALTE LICHT EIN & AUS
    if (tonumber(fibaro:getValue(motion, "value")) > 0 ) and (tonumber(fibaro:getValue(switch, "value"))) < 1 then
     fibaro:call(switch, "turnOn");
     fibaro:debug("Schalte Licht ein");
    -- Verzögerung in Sekunden (120 entspricht 2 Min) nach der letzten erkannten Bewegung, bevor das Licht ausgeschaltet wird
    if (tonumber(fibaro:getValue(switch, "value"))) > 0 then
     local starttimer = 120;
     local timer = (starttimer);
     fibaro:debug("Starte Timer");
     repeat
     fibaro:sleep(1000);
     -- Schalte Licht aus, wenn Schalter manuell betätigt wird und warte 10 Sekunden, um ein
     -- versehentliches (erneutes) Aktivieren der Szene zu verhindern
     if (tonumber(fibaro:getValue(switch, "value"))) < 1 then
     timer=1;
     fibaro:call(switch, "turnOff");
     fibaro:sleep(10000);
     break
     timer=timer-1;
     -- Timer zurücksetzen, wenn neue Bewegung erkannt wird innerhalb der Verzögerungszeit
     if (tonumber(fibaro:getValue(motion, "value"))) > 0 then
     timer=starttimer;
     fibaro:debug("Resete Time, Bewegung erkannt bzw. Motionsensor sendet noch nicht (vgl. Parameter 6)");
     until (timer<1)
     -- Schalte Licht aus, wenn Timer vollständig abgelaufen ist
     fibaro:debug("Timer abgelaufen/Schalte Licht aus");
     fibaro:killScenes(scene);
    I have a Start-Timer not found in HC3
    Hello, you didnt understand the LUA coding in the HC3 device, it´s a wrong...
    Very simply - the left part is/are the triggers (triggering condition) of the entire scene.
    The right part is the scene, the code that will be started/executed if the conditions in the left part are met.
    Try to learn it from the beginning -
    Edited by Jiri Dobsovic
    Did you get it running?
    unfortunately not yet. It only works with lots of block scenes. I have not yet managed to combine it into one scene. For the Christmas scene, I have 4 per area where I set it, 1. morning on - at a certain time, 2. morning off - 10 minutes after sunrise, 3. evening on - 10 minutes before sunset and 4. evening off - at a certain time.
    And the Light so long movement, I have only had 2 block scenes so far. 1. motion detected - switch on, 2. light off if no motion - motion sensor no motion “true for 1 minute" then switch off.
    I'll try to read a bit more about Lua in HC3 when I have some time.
