Hi guys,
I have an old QA that work flawless since last update.  Here the error of the crash:
[02.01.2025] [22:42:01] [ERROR] [QUICKAPP512]: QuickApp crashed[02.01.2025] [22:42:01] [ERROR] [QUICKAPP512]: Unknown error occurred: LuaEnvironment: /opt/toolchains/aarch64-buildroot-linux-gnu_sdk-buildroot/aarch64-buildroot-linux-gnu/sysroot/usmqtt/endpoint.hpp:2219: void mqtt::endpoint::async_publish(mqtt::endpoint::packet_id_t, std::string, std::string, mqtt::publish_options, mqtt::endpoint::async_handler_t) [with Mutex = std::mutex; LockGuard = std::lock_guard; long unsigned int PacketIdBytes = 2; mqtt::endpoint::packet_id_t = short unsigned int; std::string = std::__cxx11::basic_string; mqtt::endpoint::async_handler_t = std::function]: Assertion `(pubopts.get_qos() == qos::at_most_once && packet_id == 0) || (pubopts.get_qos() != qos::at_most_once && packet_id != 0)' failed.
the QA is this one by the way:
Any guess?
Edited by Fyase
    @m.roszak
    I guess that this behavior is more on the HC3 side, Am I wrong? QA works on all the previous versions....
    Yes, you are right :)
    It was mentioned here:
    5.172 beta has this fixed.
    Thanks...
    I'll wait for the beta to be published
