On a light switch the battery went empty. I replaced it but can't get it to work.
It seems to wait for wakeup for ever.
Is there any way to manually wake it up?
thank you in advance,
Kind regards,
Mattijs
HomeCenter 3
Heatit z-push Button 8 white
try to hold the 1 and 0 of the group 2 like including it to the gateway for 3 sec. I think that should wake it up 🤔
    Thank you very much!
    I missed your reply. Nothing happens yet. Battery is full - I can see in the dashboard. No matter how long I wait or what buttons I press; it just doesn't work.
    • 5 months later...
    Remove it from your controller and reconnect.
    Or try to connect with an other controller to check it (reset first).
    Or reset the device to factory default and reconnect to your controller.
    Edited by Casa Domotica
