Profile Light Controller
Here is my Profile Light Controller I have been working on :D
LUX Edition:
Markedplace:
It is a fast way to get Motion Lights up and going. Just upload it to the room and choose from the dropdown menus.
This controller support motion sensor and Profile handling of Lights.
Choose the lights and sensor to use from the room the controller is in.
(can also use the Qvar to the room you want to controll to have the controller in an other room)
You can also store 6 custom Scenes (rename the scenes in the Qvars scene1 and scene 2.... - standard 100% and Dim)
To save the scenes just hold down the Save 100% or Save Dim button for 2sec when the lights are set as you want them to be.
Scenes also support rgbw2 controller programs and colors :D
To setup motion for each profile (max 10 profiles supported)
choose from the dropdownlist below the table/chart.
then choose what should happen on Pir ON /OFF Events (basic timer)
Also possible to choose what should happen ON/OFF delay event (Delay ON/OFF Timers)
(example 2min after pir ON event that set lights to 20%, set the light 100%(wakeup lights))
Then you can also choose what should happen when the profile change to example home/night etc.. Or even a delay after the change.
The priority sec is if you have alot of controllers u can set 0sec delay on the controller that should act first. Then set 1-2sec more on the next.
This is because you want the bedroom to act first when going to bed and first when you wake up for example :)
and in the end you can change times for each profile by the + - change and sec/min/10xmin buttons.
if you want the controller in an other room just set the quickapp variable roomid to the room you want to control :)
Labels can be changed colors with the Qvars color1,color2..
(might add support for theme colors)
It also support Language:
en  -  English
no  -  Norwegian
de  -  German  (thanks stycx -
pl  -  Polish  (thanks raffsa -
fr  -  French  (thanks Tony270570 -
Some words/lines are added by Google translate so if you think it should be writien in another way hit me up :D
If you could help make support for other languages just hit me up on the forum:
Or in this thread:
Also post in the topic above if you have anu suggestions or wishes :D
if using the S2 input of the Fibaro dimmer 2 or the S2 input of Heatit zm Dimmer:
dimmer2s2  have to use the ID of the LAMP not the Remote!!!!!
heatits2   have to use the ID of the REMOTE!!!!
Special Thanks to @jgab
Nothing could have been done without his Eventlib and guides on the forum!!
Changelog:
5.1.25
First Release (fixed some bugs)
9.1.25
bug fix with disable/enable motion sensor
Better Error handling if motion sensors or light isnt in the room
15.1.25
Bu fix with Colorprograms and energy device showing in the select list on rgbw firmware 5.1
Edited by Brors94
Added Lux edition.
6 answers to this question
Would it be possible to add a Lux indicator to set a threshold for how dark it should be before the light turns on?
    it should be possible😄
    Do you want it to be a global for all pir on events like the pir disable buttons?
    or an extra on the pir on event and profile change events? 🤔
    Per room would likely be the most precise and customizable option. If possible, it would be great if the house profile could override the Lux rule when needed.
    I have also seen that you previously tried to create a Zaptec Go QA. Did you manage to get it working, and are you using it?
    Ill make one threshold for the pir on events and one for pir off events I think 🤔
    and the profile change events skips the lux values maybe? 🤔
    I havent been looking into it anymore. since I am using "Heatit Renergy zaptec quickapp" so havent been needing to make one myself.
    But I am considering making one that take advanrage of the renergy system and make it possible to adjust the current on the zaptec charger to.
    Just havent had time to do it :D Since the Renergy zaptec quickapp only allow start/stop/pause/status update.
    Sounds good! Just to clarify, will the Lux threshold be per room/PIR?
    Does it cost anything to get the Renergy QA for an existing system?
    Finaly got some time to add Lux sensor to this Controller.
    Check it out in the first post :)
