I added 4 Hikvision cameras to HC3. Everything works without any issues. The problem is that none of the cameras appear in the Yubu app on iOS.
Hi @HisaMiha ,
I had oposite situation, none of my cameras were working in browser, but all were visible in Yubi Home app. I have 5 Netatmo and 3 Foscam cameras. After Fibaro checked my installation now they all working on both browser and Yubii home.
BTW - I'm always remotely connected with Yubii Home app. Didn't check if local connection is working too.
    Issue resolved:
    In the Yubii app, I found the cameras in the Surveillance menu, and they display correctly.
    10 hours ago, Sankotronic said:
    Hi @HisaMiha ,
    Hi!
    Maybe the problem is with the Stream URLs configuration. What do you have written there?
    @Sankotronic, any progress QA Netatmo presence camera?
    Hi @HisaMiha ,
    Netatmo cameras are a bit different than usual IP cams. I have made scene that gets their local path to the stream which I then copy to JPG and MJPG stream path:
    /xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/live/snapshot_720.jpg
    For Foscam cameras MJPG path does not work:
    cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=<user>&pwd=<password>
    so I use JPG stream path:
    cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=<user>&pwd=<password>
    set to refresh every 2 seconds. It is not ideal solution, but it works.
    BTW - video stream on Foscam cameras is set to MJPG and not to H264, but for some reason GetMJStream is not working as expected.
    Hi @Sjakie ,
    Not yet. I'm still busy with testing some solutions and making code snippets for various repeating actions within QAs. Also I need to get better understanding of profiles and custom events and how to use them and to reduce as much as possible use of the global variables.
