Good morning,
I would like to ask how to obtain current temperature reading in the certain climate zone - o.e. bathroom, kitchen. But - is it possible when not referencing to the particular device acting as thermometer assigned to the zone? Thermometer device can be changed and I still want to read correctly.
Most natural way seems:
api.get("/panels/climate")
but can't see the current temperature reading among many other data.
This might do it:
    var = api.get("/panels/climate/"..ID_climate_panel.."").properties.currentTemperatureHeating  --- heating
    print("var",json.encode(var))
    var = api.get("/panels/climate/"..ID_climate_panel.."").properties.currentTemperatureCooling  ---cooling
/monthly_2025_01/image.png.db75a59ee63f346430725f3b48353297.png" />
    I think it's not what I want. I need to read current real temperature in the zone from the assigned to zone thermometer.
    Or, maybe better, how to obtain id of the thermometer associated with certain climate zone?
    Like this :)  (this is with 2 sensor you se the "avg" calculation) :D
        var = api.get("/panels/climate/"..ID_climate_panel.."").properties.temperatureSensors
    from swagger:
    console print:
    Well, I don't check and do a comment. Apologise!
