Lua Scene Declaration issue
Hello
Can anyone check below code and correct me if anything wrong, i am writing below code for condition like when it's between 6:50 to 22:00 in weekdays (Sunday to Friday) and trigger below 2 conditions are true like ID: 225 Thermostat mode to be cool mode and ID : 226 >=20 steady for more than 10 seconds then only execute function in ACTION TAB but in my case its triggering when ever ID:226 changes value >=20 instead of waiting for 10 seconds.
  conditions = { {
      isTrigger = false,
      operator = "match",
      property = "cron",
      type = "date",
      value = { "*", "*", "*", "*", "1,2,3,4,5,6", "*" }
      conditions = { {
          isTrigger = false,
          operator = "match>=",
          property = "cron",
          type = "date",
          value = { "50", "06", "*", "*", "*", "*" }
          isTrigger = false,
          operator = "match<",
          property = "cron",
          type = "date",
          value = { "00", "22", "*", "*", "*", "*" }
      operator = "all"
      duration = 10,
      id = 226,
      isTrigger = true,
      operator = ">=",
      property = "value",
      type = "device",
      value = 20
      id = 225,
      isTrigger = false,
      operator = "==",
      property = "thermostatMode",
      type = "device",
      value = "Cool"
  operator = "all"
7 answers to this question
Try do nest the duration-criteria.
I.e add { before and } after the duration
      conditions = { {
          {duration = 10},
          id = 226,
          isTrigger = true,
          operator = ">=",
          property = "value",
          type = "device",
          value = 20
      operator = "all"
    still its triggering action without 10 seconds wait.
    13 minutes ago, Nadeem said:
          {duration = 10},
    Without the {}
    i tried that in my first message and its working immediately without duration command time.
    In the first message you have a lot of other conditions
    yes later i removed all and tested only triggered condition. which is
      conditions = { {
          duration = 10,
          id = 226,
          isTrigger = true,
          operator = ">=",
          property = "value",
          type = "device",
          value = 20
      operator = "all"
    Perhaps a couple of errors
    try this:
    isTrigger = false for ID: 226 → Prevents immediate execution on value change
    duration = 10 applies to the entire condition group → Ensures ID: 226 stays >= 20 for 10 seconds before triggering
    operator = "all" ensures all conditions are met before execution
