Fibaro Home Center 2, hanging and not bootup after power failure
After i lose power or power failure, my home center two doesn't boot up automatic as it was doing before, i tired reset and restore backups and everything but no hope, I have to press the power button until it shut down then turn it on again to work.
any solution for this issue ?
Have you tried to set the HC2;into recovery mode?
Hello, there was a Thread about this Problem a while Ago that helped in one of my Installations.
The HC2 in my Case had been in use for around 5 Years when the CMOS Battery gave up. After replacing and checking the Bios Settings like described there everything was working again.
