Hi @m.roszak,
Usually automatic logout works the way if user does not interact with GUI home page for some certain time then automatic logout is preformed and login page should appear in browser.
Unfortunately this is not the case with Fibaro HC3(L), Yubii firmware.
I noticed if I was not interacting with GUI home page for some time, automatic logout is preformed, but home page remain in browser and usually show wrong statuses of the installed devices. In that case, I can still interact with GUI, scroll, filter, but when Settings is clicked then login page appear.
Even worst is that in many cases automatic logout is preformed even I was constantly busy clicking around my QAs and editing them. It happened several times that I was not able to save QA after correcting code, but after refreshing page then login page appear asking me to login to my HC3 to continue work.
It is not very often, but it happens enough times to start annoying me :-(
BTW - this appeared at least several versions before this last beta. Since nobody else reported it till now, I guess that other users do not work that long as me, or they are regularly  logging out, while I like to stay logged in for long time :-P
25 minutes ago, Sankotronic said:
Hi @m.roszak,
One of the reasons I use VS code fibemu jgab have provided :D
I have also noticed it, but havent sent it as a case for support 😅
But I can confirm this happens somtimes!
I noticed also that behavior. I use since that is happening often Zerobrane to modify and copy back in to HC3.
It is randomly sometimes after 4 saves  or sometimes not at all.
Edited by Sjakie_
