HCL scenes stops working, only Fibaro can reset
My HCL generally works fine but it needs to be reset by Fibaro every month or so. I have asked Fibaro what i can do to prevent this, the say "The database of your gateway was full. You can make the report intervals of your devices bigger.....". But the storage says 5%used space.
I have increased report intervals, but I still have the same problem.  I have reset energy data both in "General information" and individually in all the devices. It still needs Fibaro to reset the database.
Anyway, Fibaro does something and it works again.
But is there anything can do to prevent this from happening?
@JohanSj HCL is EOL end of life, no more updates. If the fibaro support can't solve the issue, I recommend you to upgrade to a homecenter 3 or two Yubii home controllers if your zwave devices aren't in the same building.
The Fibaro homecenter comparison list is
