Hi, Today I found the HC3 not in function. It was red text saying something about som error and that I should do recovery. I did but now it is stucked in starting service mode, I have logged out, logged in again, refreshed page but still same problem. I also see that many heat controllers now are in full open mode = Very hot in some rooms. Need some urgent help. 😊
@HC3-00001183 Hello and welcome to the community.
You should not show your HC3 Serial Number in the Internet.
Things you can try:
-Deltete browser history
-Try with another browser
-Contact [email protected]
  • 1 month later...
That sounds really frustrating! If the HC3 is stuck in "starting service mode," you might need to do a full power cycle—unplug it for a few minutes and restart. Also, check if there's a firmware update available. If the heat controllers are fully open, you might need to manually adjust them for now. Hopefully, someone here has experienced this and can offer a fix! 😊
_______________
Edited by sadoudi
  • 3 weeks later...
If you haven't tried this yet, try accessing your HC3 via the Fibaro mobile app or another management interface to see if you can manually reset or adjust the heating controllers.
