French-CF 0
I have been using several The Heat devices for years and have been very satisfied with their performance. However, since the last update for my HC3, the temperature offset feature has been removed.
As a result, the temperature is now reported at 20°C (for example), when it is actually only 18°C. Without the ability to offset the temperature device, it undermines the fine control benefits that a home assistant should provide.
Could Fibaro consider making this offset feature available again, or will we have to discard our The Heat devices?
I am available to discuss any potential solutions to manage this issue.
Thank you, Cyril
