Update 2.3.2 No connection to units (iOS)
Today's update and I'm blind! All units are unavailable! :((((
Same here, this is insane. I deleted the app and reinstalled it but the HC3 is still unavailable
Same here!
    Can't even use local wifi access! I don't get it
     we are checking problems
    Same here, can't get access to the HC3 at all, not via the app neither via webclient, installer indicator is red.
    This has nothing to do with this latest app update. Servers are down or under attack. Please check related topic here:
    Thank you!
    Same issue. NO ACCESS whatsoever from iOS app.
    Thank you!
    Thanks for the info, but the app is poorly written then! It is not possible to select local access in the menu! Before I enter the local details it tries to connect to the cloud and this option is disabled, do things for people and not for IT experts, I don't understand how it is possible to have such a fundamental problem with an app that controls a household!
    Hi @petro_cz ,
    What you are complaining about selecting local or remote connection within the app definitely deserves its own topic, don't you think so?
    I suggest that you open topic about Yubii Home app local vs remote connection.
    problem solved, it works now
    • Thanks 2
