heat controller does not stop heating
Could anyone help what is wrong with my Heat controller? I have the schedule set to 21 degrees, I overwritten it manually in app to 19, and my heat controller does not stop heating. I have already almost 28 degrees shown by sensor and radiator is super hot... Manually, on the heat controller it does not react as well.
@XiaoTu Check if the controller is mounted correctly.
If you use an adapter, check if the adapter fits and is fixed.
unmount and mount the heat controller again. Do it step by step according to the user manual
The heat controller troubleshoothing is
I have exactly the same issue you have. Imo this is a big problem. I tried to reinstall controller but nothing helps. If this problem occurs then it will heat forever even if you turn it off. I found workaround for it - change temperature higher then it is and later turn it off or recalibrate it again. I know this is stupid but this one works for me. Pls fix this!
Edited by memus
