mm553 0
I have a question regarding the Fibaro Double Switch 2. Is it possible to differentiate between a single and double click using Direct Associations when the receiving device is also a Fibaro Double Switch 2?
Specifically, I would like to achieve the following behavior:
- A single click should trigger output Q1 on the receiving Fibaro Double Switch 2.
- A double click should trigger output Q2 on the same device.
Can this be done with Direct Associations? If so, how should it be configured? Any help or insights would be greatly appreciated!
Thank you in advance!
