    42 minutes ago, GeeMoney said:
    Not sure why the push options were originally built in? I personally don't need them perse. I Just want to receive a push when the temp drop happens that would be nice but that can also be done by the child trigger device because I use that one as a trigger in a scene which works perfect.
    Really a nice job, thanks for all the coding and helping out really appreciate it!
    You also have experience with MQTT and Fibaro/coding ?
    Was someone on the forum that wanted to have push on temp change :)
    And I just want to build Quickapps to learn more :D And have somthing with a goal instead :)
    I havent done anything with mqtt 😅 And know litle about it :) But I know @jgab got some library/examples that uses mqtt :)
    So I might look into it one day. But not in the near future 😅
    No problem :)
    The QA with the temp drop is excellent, thanks for the work. I Have added 4 of them to monitor all my thermostats :) and when it detects a drop, the heating is turned off for a period of time.
    Another QA that I really miss is the integration with Electric cars.
    Tesla/Audi/Volkswagen/Skoda (VAG) all don't have a QA available for Fibaro but do exist on HomeAssistant for example.
    The VAG group all work the same, so when you have 1 working, it's just copy & paste for the different brands.
    If you are up for a challenge, take a look at stuff like that.
    I Will try and focus on the MQTT for my heat pump(s) currently they are connected to HomeAssistant for that but I would like to transfer everything to Fibaro.
    Edited by GeeMoney
    7 hours ago, GeeMoney said:
    No problem :)
    Glad it works for your heating :D
    If you have home assistant green or on something else, try this integreation :)
    Lets you import most devices from ha to fibaro :D
    have to do some setup but works nice for the few things I have :D
    And QA for all the carbrand is somthing i rather take with the home assistant integration :D way to mutch to update to make somthing like that..
    Thanks for linking, I've seen that one but the problem is that I have created my own devices in HASS as well but support for MQTT etc. is much easier than Fibaro.
    I will try to translate but the main issue is time :)
