Integration Shelly PRO 4PM into HC2
I would like to integrate my Shelly PRO 4PM into my Fibaro HC2 as I have my LUA scripts running here (I have also Home Assistant, but prefer to integrate into the LUA as for me the main automation is done here).
I managed basically to switch the relays, however only 3 of 4...
Just an example to turn on the second relay:
The first relay is 0 therefore I'm using "/relay/1?turn=" for the second relay. However when using "/relay/3?turn=" for the fourth the switch is not doing anything... Anybody who knows how to fix this?
Another issue I have, is reading the status. When using /status after the IP address locally, it says "Not found".
Most of the Shelly products support this, however the 4PM doesn't. Anyone who knows how to get the status of the 4 relays?
