I publish values for the energy panel and you can see these publications in the history, however in the energy panel in savings some of these measurements are not included (they are equal to 0), would anyone have an idea how to solve this? Values are downloaded through the API in QuickApp and then saved in a table from which kWh are calculated and saved to the parameter “value” which is responsible for sending data to the energy panel. Thanks in advance for your help!!!
Do you want a flat line of the kWh in the panel in stead of the ups and downs?
    At the moment there is no one at home so the graph should be flat but some of the measurements that he makes available on the energy panel are not visible on the graph (in the history you can see that a measurement has been added)
    The energy panel calculates with cumulative values. So the energy panel kWh values are calculated from the difference between the previous and new value.
    If you want a flat line at 0.15 kWh you probably need more than an hourly value (and make sure you don't insert 0 values).
    • 3 weeks later...
    I add 12 measures per hour and i still don't have the flat line
    The problem is when i devide the vale more then 12 times the energy panel see the value as 0. Then i make 4 measures per hour and i still dont het the flat chart.
    Do you think the reason is too low value of measure, hourly value shoud oscillate around 0,12 kWh.
