Łukasz997 123
Good evening,
despite the winter is nearly over here, I undertake a task to improve my heating system.
It consists from several heat controllers, smart implant in heater and Fibaro plugin.
It's working more than less ok, when the head are so kind to communicate with central properly (no "orphaned" heat required etc).
Sometimes happen that the temperature should be raised a little, but the valve in heat controller seems to be closed. And the oven is on for 12 hours (only pumping water in the hydraulic cluth), on example.
A solution seems to me to open the heat to the full (or in contrary scenario - close) by setting the temp to MAX. This decision would be made after fulfilling some common conditions.
What's the problem to me - is the source of temperature measurement. It's not always but often: head thermometer, zone temperature schedule page (the same device selected to measure), json from /panels/climate and Yubii app reads different values of temperature.
Why is that? I would like to ask about short lecture about the temperature measurement in HC3. I hope that someone also meet such problem.
