What is needed to enable DALI on FIBARO
Hello Guys,
I have track lights in every room (4 rooms altogether), the electricity cable is 5-wire. I would like to get integrated DALI track lights but i am not sure what devices should i buy to get it working.
i know that there are contgrollers
or i should buy something from euLINK?
i am totally confused :/
Can anyone guide me a bit?
Shafran
Edited by Shafran
mispelling
@Shafran
Eulink works nice here :)
Only thing I have experienced bad with Eulink was a corrupt sd card. Had to change the sd card and load a backup and was up and running again 😄 (couldnt control the lights for a day😅 Had to use  the fuses)
And maybe they will support Dali2 standard later so we can use button inputs/sensor from dali in the fibaro world to later :D
The z-wave to dali is okey, had an issue where I used 3 of them and sendt a command to all 3 of them at the same time. (3 diffrent dali groups)
The dali bus seem to only handle 2 of the commands sometimes and somtimes all changed.
But by setting a timeout of 150ms between each command it seemed to work okey
So in the end I recommend the eulink the most 😄
Edited by Brors94
