Issue with "Waiting for wakeup or synchronization" on HC2 and Fibaro Dimmer 2
Hello everyone,
I am facing a curious issue with one of my Fibaro Dimmer 2 modules. Despite the module functioning correctly in all respects, the "Waiting for wakeup or synchronization" message is persistently displayed in the parameters section on the Fibaro Home Center 2 interface. This is specific to this module, as my other Dimmer 2 units do not show any such message. Both the affected Dimmer 2 and the HC2 are updated to the latest software versions.
Has anyone else encountered this scenario where the device operates properly but the interface shows an error message? How can I resolve or clear this error from the parameters? Any insights or troubleshooting tips would be greatly appreciated.
Thank you for your assistance and suggestions!
Edited by georgecdv
Hi @georgecdv ,
It is not really waiting for dimmer 2 to wake up since it is mains supplied device. This only means that parameters settings in dimmer 2 and HC2 are not synchronized. Open dimmer and select Advanced tab. Scroll down to find "Read configuration" button press it and wait until parameters are received from dimmer 2. After all parameters are received by HC2 a small window will popup to ask you to refresh page. After that notification "Waiting for wakeup or synchronization" should disappear.
