pbtinus 0
Hi, I'm not a LUA specialist but I like to make my own LUA scenes and quickapps mostly by trial en error, alot of Googling and ofcourse Chatgpt
after strugling for a few weeks I need some help because I'M stuck....
I use a standard sonos player that I can adjust and add funtions to like selecting the line-in on my sonos five to play a record.
but now im struggling to get spotify working. (or playing a sonos favorite) by pressing a button in my sonos quickapp.
The QA I would like to create is a simple player with a couple of buttons to select playlists or favorites (layout as attachment)
Is there anybody that can help me with the correct code? (chatgpt has helped me a lot but i cant get it to work ... )
the URI im using that doestnt work: "x-sonos-spotify:spotify:playlist:7jBDsDWvg7FXEqo91CcUpE?sid=9" or "x-sonos-spotify:playlist:7jBDsDWvg7FXEqo91CcUpE?sid=9"
if I change it into a single track, it works.
complete code for the button:
function QuickApp:hard()
-- De URI van de Sonos-favoriet voor Tinus Soft
local favoriteUri = "x-sonos-spotify:spotify:playlist:7jBDsDWvg7FXEqo91CcUpE?sid=9"
-- Controleer of favoriteUri een geldige string is
if not favoriteUri or type(favoriteUri) ~= "string" then
print("❌ Ongeldige favorite URI")
return
-- Controleer of AVTRANSPORT_URI is ingesteld
if not self.AVTRANSPORT_URI then
print("❌ Fout: AVTRANSPORT_URI is niet ingesteld.")
return
-- Log de URI voor debugging
print("📡 Verzenden van URI naar Sonos: " .. favoriteUri)
-- Maak het XML-verzoek voor de AVTransport-service
local function createAvTransportBody(uri)
return string.format(
'<u:SetAVTransportURI xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">' ..
'<InstanceID>0</InstanceID>' ..
'<CurrentURI>%s</CurrentURI>' ..
'<CurrentURIMetaData></CurrentURIMetaData>' ..
'</u:SetAVTransportURI>',
uri
local requestBody = createAvTransportBody(favoriteUri)
-- Verzend het verzoek naar Sonos om de URI in te stellen
self:sendRequest(
self.AVTRANSPORT_URI,
'"urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI"',
requestBody,
function(data)
if data then
print("✅ Tinus Soft favorite is succesvol ingesteld!")
-- Controleer of de play-functie bestaat
if self.play and type(self.play) == "function" then
print("▶️ Afspelen van de playlist...")
self:play()
else
print("⚠️ Fout: play-functie bestaat niet of is niet aanroepbaar.")
else
print("⚠️ Geen respons van Sonos bij het instellen van de favorite.")
end,
function(error)
print("❌ Fout bij verzenden van verzoek naar Sonos: " .. tostring(error))
