Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Devices
    HeatIt Z-Temp3 support added.
    Fantem Home Energy Meter Gen 8 support added.
    Aeotec Home Energy Meter Gen5 2P (US region) support added.
    Added a possibility to change HVAC devices icons.
Gateway Connection
    Possibility to connect hubs from different networks based on provided IP.
Nice*
    Optimized network configuration for better performance.
    Domi WSC parameters template updated.
Other
    System boot-up procedure performance improvements.
Plugins
    Added support for Satel Integra 256 in old FW revision.
Scenes
    Default behavior for predefined scenario changed - from now no devices are selected by default.
Z-Wave
   Z-Wave radio module SDK updated for Yubii Home and Home Center 3 Light.
Zigbee
    Introduced the mechanism which prevents losing the network configuration in very rare cases.
    MOES Human Presence Sensor ZSS-QY-HP (and other revisions) support added.
Bug Fixes:
Access
    Installer does not see system notifications for administrator.
Backup
    Error while uploading a Cloud backup in rare cases.
Cameras
    Lack of local preview for some cameras in Safari browser.
Devices
    Custom icons do not work for CO Detector device type.
    Lack of correct icons for Silent Open and Silent Close actions on the control dialog.
    Thermostat Linked Device - fixed the issue when cooling and heating actor is the same device.
    Qubino Flush Dimmer 0-10V - fixed optional temperature sensor handling.
    Restored old sets of icons for some device types.
Energy Panel
    Error during saving Energy Panel settings in some cases.
Gateway Connection
    Issue with listing slaves list in large IP network.
    Restoring a backup after replacing a slave with new unit fixed.
    Stability improvements.
History
    Missing thermostat set-point name in history entities.
Nice*
    Fixed binding procedure from the mobile app for BiDi-Multisensor.
    Corrected parameters template for TT2NBD.
Other
    Small UI/UX fixes.
Plugins
    Missing IP field configuration in Philips Hue.
    Fixed issue with Nice Cameras support in scenes when passwords with special signs are used.
Quick Apps
    Dropdowns does not work correctly when new view is disabled for mobile application.
    Function setColorComponent doesn't refresh the view when custom color components are used.
    Template for Color Controller device type updated.
Scenes
    Fixed setting slats position for FGR-224/Rol-Control2 group in block scenes.
    Fixed issue in Custom Scenarios when FGKF-601 is used as a trigger.
Z-Wave
    Fixed issues with mesh network reconfiguration.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
