Seems like we are missing a new tab in the more option to see this new "notifications" in the app.
after triggering a massage by reading a z-wave device I get this red dot:
Same here, cant find this notifications in app on ios.
Same here.
I find 'notifications' on the tablet, but not on the phone.
Thanks for your feedback. We are currently investigating an issue that may be causing the notification panel to not appear in the app. To help us rule out a few potential causes, we kindly ask you to clear the app's cache or, if possible, uninstall and reinstall the app.
Best regards, Angelika
"Clear applications data" -> no change
delete and install yubii app -> solved the problem
Confirm that delete and install works.
    Worked after reinstall here to :D
    Have to make some use of this in QA's to 🤔 Html not supported 😞
    Inn the webview of the message center it is support for html color, But not the \n for next line, But in the yubii app the \n works 😅
    @m.roszak may you adress this? :D
    I think they want you to use:
    We have identified and resolved the issue related to the visibility of the notification panel.
    The fix will be included in the upcoming application update.
    Angelika
    • Thanks 3
