Remove Fibaro device from HC3 and set discovery mode without direct access
Hello! I have Fibaro multiple devices connected to my HC3 and I want to migrate them into another hub. Main issue here is that I don't have access to some controllers physically. Some of them are hidden in places that it is nearly impossible to press reset button. Is there any way to remove that devices from HC3 and put them into learning mode?
Nope, need to push to add or delete.
Hello. IF you have for example a Roller Shutter or Single/Double Switch Module there is an Option. If you have an Switch/Toggle Switch connected to the S1 Input of the Device you can set them into Add/Exclude Mode with three presses of the connected Switch/Toggle Switch.
You may have altered the Parameters for the S1 Input so you should look into the Manual of the specific Device. You have to tinker with it for a bit to get it to work sometimes, but it has saved me a lot of Digging with People who had buried Modules in Places you will never find them ever again.
As a Tip, you should always (regardless of the need for a connected Input) connect some redundant/not used Wire to the S1 so you can do exactly that in cases you can not get to the Module easily.
    Now I'll know that 😅 Next time when I'll have access to that controllers, I'll add buttons to press the S1.
