HC3 Store a table into Global Variable
Hi All,
I want to store a table into a variable, this looks fine:
function QuickApp:onInit()
self:debug("onInit")
Table={}
local TimeHour = os.date('%H')
-- Array Session
Table[TimeHour]="1000"
Table[TimeHour+1]="1501"
Table[TimeHour+2]="2500"
hub.setGlobalVariable("TableVAR", json.encode(Table))
The TableVAR has the following content:
But now I want the read this TableVAR again back into the Table array.
That is the part I don't get to work..
Table=json.encode(hub.getGlobalVariable("TableVAR"))
Gives the error:
/usr/share/lua/5.3/json/util.lua:55: bad argument #1 to 'for iterator' (table expected, got number)
And when I try to read the Global Variable like this:
Table=json.encode(tostring(hub.getGlobalVariable("TableVAR")))
The output is:
print ("Table" .. Table)
Table"{\"12\":\"1501\",\"13\":\"2500\",\"11\":\"1000\"}"
But the I can't use this as a table..
print ("Table field 12 " .. Table["12"])
Gives an error:
main.lua:20: attempt to concatenate a nil value (field '12')
Which part am I missing here? What is the correct way to handle a table in a Global Variable?
Thanks in advance.
5 answers to this question
@Nevicare
If you read out a globalvar you get 2 return arguments: the value and a timestamp
So you need to define a variable to just save the globalvar itself
Then you can save the new variable as json table like this and there you can then use it as table
Edited by Stycx
The extra (...) discards the second result from getGlobalVariable that interferes with json.decode
    Thanks Stycx,
    That works :)
    Now I want to have a for-loop to walk through this table.
    But the for loop below doesn't give any output at all..
    print(hub.getGlobalVariable("TableVAR"))
    tableVar,_ = hub.getGlobalVariable("TableVAR")
    print(tableVar)
    Table2 = json.decode(tableVar)
    for k,r in ipairs(Table2)
    do
      print("Table " .. Table2[k] .. " output r " ..  r )
    Use 'ipair' for an array
    Use 'pair' for a key/value table
    Thanks all, that did the trick.
