ThatDude 8
I use the Smart Implant as trigger to open an outside electric gate (powered by a Nice gate motor). The gate can be opened/closed via a momentary switch, so basically by momentarily shorting two pins on the gates controll module.
I've put the Smart Module in a dedicated, hermetically enclosed plastic enclosure, along with a small 12V DC power supply. The DC power supply gets powered from the same line as the gate motor, and the smart module outputs are connected to the appropriate pins in the gate's controll module. The smart module is configured as a momentary switch (auto off after 2 seconds), and the setup works as expected. After trigerring the smart module, the gate opens.
BUT
On a random day the gate will just start to open/close constantly without any input. The events panel doesn't on HC doesn't show any imputs/outputs/events from the smart implant. This behaviour happens event when the smart implant is not powered on, but just connected to the gate controll module pins. The whole setup can be fine for few weeks, and than one day it will start to cause issues. Disconecting power to the whole gate&implant assembly for a while "fixes" the issue.
Two obvious reasons this could happen:
Did anyone expirienced such a behaviour with the smart implant?
21 answers to this question
