how to connect the fibaro dimmer 2 to existing wallswitch ( toggle )
good afternoon everybody,
i have the following situation.
i want to connect my new fibaro dimmer 2 behind an existing toggle switch. unfortunatly i have no space in this socket. so i have to place the dimmer in the socket by the lamp.
in the picture i clearly stated my current situation. behind the lamp i have a "central point" with several electric. lines. ( first text is in dutch )
can somebody explain me how to connect it properly in this situation?
i already tried something but that didn't work properly, my toggle switch didn't work in this case ( it only worked with the app )
i would appreciate it very much if somebody could help me in this in "easy language" because i am not an advanced electrician. i have basic knowledge for it.
many thanks in advance
The wiring diagram is located in the manual
. If this is too confusing for you, you really should hire an electrician to help you, 😀
